Api session event editor geotiff add ascii url
Revision as of 10:08, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add new GeoTIFF Item from Web ASCII URL. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |GeoTIFF Name | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Web ASCII URL | |- |2 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Uploader | |- |3 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |CRS | |} ===Response Codes=== {|...")
0 REQUIRED (String or multiple values in array ["a", "b", "c"]) GeoTIFF Name
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Web ASCII URL
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Uploader
3 REQUIRED (String or multiple values in array ["a", "b", "c"]) CRS
200 Integer[] (GeoTIFF IDs)
Example POST: https://engine.tygron.com/api/session/event/editorgeotiff/add_ascii_url/?f=HTML&token=API_TOKEN
with content:
[ [ "GeoTIFF Name 1", "GeoTIFF Name 2", "GeoTIFF Name 3" ], [ "Web ASCII URL 1", "Web ASCII URL 2", "Web ASCII URL 3" ], [ "Uploader 1", "Uploader 2", "Uploader 3" ], [ "CRS 1", "CRS 2", "CRS 3" ] ]
