Api session event editor geoplugin remove source
Revision as of 10:08, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove Source {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(GEO_PLUGIN Integer ID or multiple values in array [1, 2, 3]) |Geo Plugins | |- |1 |REQUIRED |(SOURCE Integer ID or multiple values in array [1, 2, 3]) |Sources | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/...")
0 REQUIRED (GEO_PLUGIN Integer ID or multiple values in array [1, 2, 3]) Geo Plugins
1 REQUIRED (SOURCE Integer ID or multiple values in array [1, 2, 3]) Sources
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorgeoplugin/remove_source/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]
