Api session event editor geolink remove additional
Revision as of 10:07, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove additional attribute injection from the created feature. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(GEO_LINK Integer ID or multiple values in array [1, 2, 3]) |CustomGeoLink IDs | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Attribute Names | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example...")
0 REQUIRED (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) CustomGeoLink IDs
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute Names
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorgeolink/remove_additional/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ] ]
