Api session event editor building reset slanting roof height
Revision as of 10:05, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Reset height of the slanting roof of a building section {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(BUILDING Integer ID) |Building ID | |- |1 |REQUIRED |(Integer number) |Section ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorbuilding/reset_slanting_roof...")
0 REQUIRED (BUILDING Integer ID) Building ID
1 REQUIRED (Integer number) Section ID
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/reset_slanting_roof_height/?f=HTML&token=API_TOKEN
with content:
[ 98, 93 ]
