Api session event editor building reset function values
Revision as of 10:05, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Reset Function Values {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(BUILDING Integer ID) |Buildings | |- |1 |REQUIRED |(FunctionValue or multiple values in array [a, b, c]) |FunctionValue[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorbuilding/reset_fun...")
0 REQUIRED (BUILDING Integer ID) Buildings
1 REQUIRED (FunctionValue or multiple values in array [a, b, c]) FunctionValue[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/reset_function_values/?f=HTML&token=API_TOKEN
with content:
[ 39, [ "LIVABILITY_EFFECT", "HEAT_EFFECT", "JAM_FACTOR_BUSES" ] ]
