Api session event editor area import
Revision as of 10:01, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Import Area Collection
0 REQUIRED (GeometryCollection with crs: EPSG:3857) Collection of Area geometries
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Area Names
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute Names
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Attribute Values
4 OPTIONAL (Floating point number) Buffer for Points and Lines to make Polygons (optional)
5 OPTIONAL (SOURCE Integer ID) Source (optional)
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editorarea/import/?crs=3857&f=HTML&token=API_TOKEN
with content:
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799344.9643746065 ], [ 658740.349251597, 6799344.9643746065 ], [ 658740.349251597, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799457.201080266 ], [ 658697.1391108201, 6799457.201080266 ], [ 658697.1391108201, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799311.322575467 ], [ 658704.5224335027, 6799311.322575467 ], [ 658704.5224335027, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "Area Name 1", "Area Name 2", "Area Name 3" ], [ "Attribute Name 1", "Attribute Name 2" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ], [ 7.0, 8.0 ], [ 9.0, 10.0 ], [ 11.0, 12.0 ] ], 0.5, "" ]
