Api session event editor address set point
Revision as of 09:54, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set the point of an address {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(ADDRESSE Integer ID or multiple values in array [1, 2, 3]) |Address ID | |- |1 |REQUIRED |(Point with crs: EPSG:3857 or multiple values in array [a, b, c]) |Point | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/ses...")
0 REQUIRED (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) Address ID
1 REQUIRED (Point with crs: EPSG:3857 or multiple values in array [a, b, c]) Point
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857&f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ {
 "type" : "Point",
 "coordinates" : [ 658709.3509901097, 6799375.968744127 ]
 "type" : "Point",
 "coordinates" : [ 658683.8845361582, 6799304.4802202815 ]
 "type" : "Point",
 "coordinates" : [ 658665.1014022329, 6799445.533301746 ]
