Api session event editor area set relation
Revision as of 08:38, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Relation {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(AREA Integer ID) |Areas | |- |1 |REQUIRED |(Enumeration) |Relation |BORDER_A, BORDER_B, BUILDING, CONSTRUCTOR, DEMOLISHER, NETOWNER, OWNER, PARENT, PERMITTER, RECEIVER, RESULT_PARENT, SENDER or WEATHER |- |2 |REQUIRED |(Integer number) |Integer | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overv...")
0 REQUIRED (AREA Integer ID) Areas
1 REQUIRED (Enumeration) Relation BORDER_A, BORDER_B, BUILDING, CONSTRUCTOR, DEMOLISHER, NETOWNER, OWNER, PARENT, PERMITTER, RECEIVER, RESULT_PARENT, SENDER or WEATHER
2 REQUIRED (Integer number) Integer
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorarea/set_relation/?f=HTML&token=API_TOKEN
with content:
[ 93, "PERMITTER", 1 ]
