Api session event editor area remove all attributes
Revision as of 08:38, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove All Attributes {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(AREA Integer ID or multiple values in array [1, 2, 3]) |Areas | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorarea/remove_all_attributes/?f=HTML&token=API_TOKEN with content: <pre>[ [ 1, 2, 3 ]...")
0 REQUIRED (AREA Integer ID or multiple values in array [1, 2, 3]) Areas
204 No Content
with content:
[ [ 1, 2, 3 ] ]
