Api session event editor area generate sewer areas
Revision as of 08:38, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Generate Sewer Areas {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(Integer number) |Integer | |- |1 |REQUIRED |(Floating point number) |Double | |- |2 |REQUIRED |(Floating point number) |Double | |- |3 |REQUIRED |(Floating point number) |Double | |- |4 |REQUIRED |(String) |String | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer (Integer) |- |300-600 |Codes Overview |} ===Example...")
0 REQUIRED (Integer number) Integer
1 REQUIRED (Floating point number) Double
2 REQUIRED (Floating point number) Double
3 REQUIRED (Floating point number) Double
4 REQUIRED (String) String
200 Integer (Integer)
Example POST: https://engine.tygron.com/api/session/event/editorarea/generate_sewer_areas/?f=HTML&token=API_TOKEN
with content:
[ 7, 25, 1, 0, "Text" ]
