Api session event editor area add with attribute
Revision as of 08:38, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add With Attribute {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(String) |String | |- |1 |REQUIRED |(Floating point number) |Double | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer (Integer) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/?f=HTML&token=API_TOKEN with content: <pre>[ "Text", 29...")
0 REQUIRED (String) String
1 REQUIRED (Floating point number) Double
200 Integer (Integer)
with content:
[ "Text", 29 ]
