Api session event editor area append attribute
Revision as of 08:37, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Appended to existing Area attribute value {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(AREA Integer ID or multiple values in array [1, 2, 3]) |Areas | |- |1 |REQUIRED |(String) |Attribute Name | |- |2 |REQUIRED |(Floating point number or multiple values in array [1.0, 2.0, 3.0]) |Attribute Values appended to existing values | |- |3 |OPTIONAL |(SOURCE Integer ID) |Source (optional) | |} ===Response Codes=== {|cl...")
0 REQUIRED (AREA Integer ID or multiple values in array [1, 2, 3]) Areas
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Attribute Values appended to existing values
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorarea/append_attribute/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ], "" ]
