Api session event editor area add polygons
Revision as of 08:37, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add polygons to existing Area {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(AREA Integer ID or multiple values in array [1, 2, 3]) |Areas | |- |1 |REQUIRED |(MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) |MultiPolygon[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.t...")
0 REQUIRED (AREA Integer ID or multiple values in array [1, 2, 3]) Areas
1 REQUIRED (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) MultiPolygon[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorarea/add_polygons/?crs=3857&f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799301.862164233 ], [ 658729.0972367388, 6799301.862164233 ], [ 658729.0972367388, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799427.10916011 ], [ 658651.7851103995, 6799427.10916011 ], [ 658651.7851103995, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799364.590175445 ], [ 658739.7856763724, 6799364.590175445 ], [ 658739.7856763724, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
