Ground water level area (Subsidence Overlay)
Revision as of 14:04, 16 March 2026 by Maxim@tygron.com (talk | contribs)
This functionality is deprecated and will be removed in the future.
Ground water level areas are areas which can be used to define the initial ground water level, when detailed raster data of ground water depths is not available.
  • Water level areas and subsidence areas can also be ground water level areas at the same time.
