How to import 3D Models from ArcGIS Online
How to log in an ArcGIS Online account in the Tygron Client Application:
- Click on the Community tab and click on Sign in with ArcGIS
- In the new panel that pops up, choose Default ArcGIS Online and click on Continue to login
- Fill in your username and password
- Upon success, a confirmation message appears and the panel closes automatically.
- To add private or organizational data, see the instructions below.
Sign in with ArcGIS link in Community Tab of the ribbon bar.
Arcgis default Login panel
Arcgis Sign in panel.
Link changed when logged in with Arcgis.
How to import 3D Models from ArcGIS Online:
- Step 1:
- If your organization uses a Custom ArcGIS Enterprise Portal, select that option in the ArcGIS Login panel. An additional access token is required for the Tygron Platform to communicate with ArcGIS. Such a token [1] can be created using ArcGIS Portal for your Enterprise.
- ↑ Arcgis Access Token ∙ Found at: https://developers.arcgis.com/documentation/security-and-authentication/reference/access-tokens/ ∙ (last visited: 09-03-2026)
