How to import 3D Models from ArcGIS Online
How to import 3D Models from ArcGIS Online:
- Open a project in the editor
- Select Community in the ribbon bar
- Click on the link named Sign in with ArcGIS
- Select the option Default ArcGIS Online and click on the button Continue to login
- Sign in with your Username and Password
Sign in with ArcGIS link in Community Tab of the ribbon bar.
Arcgis default Login panel
Arcgis Sign in panel.
Link changed when logged in with Arcgis.
- If your organization uses a Custom ArcGIS Enterprise Portal, select that option in the ArcGIS Login panel. An additional access token is required for the Tygron Platform to communicate with ArcGIS. Such a token [1] can be created using ArcGIS Portal for your Enterprise.
- ↑ Arcgis Access Token ∙ Found at: https://developers.arcgis.com/documentation/security-and-authentication/reference/access-tokens/ ∙ (last visited: 09-03-2026)
