How to import 3D Models from ArcGIS Online
How to import 3D Models from ArcGIS Online:
  1. Open a project in the editor
  2. Select Community in the ribbon bar
  3. Click on the link named Sign in with ArcGIS
  • If your organization uses a Custom ArcGIS Enterprise Portal, select that option in the ArcGIS Login panel. An additional access token is required for the Tygron Platform to communicate with ArcGIS. Such a token [1] can be created using ArcGIS Portal for your Enterprise.
  1. Arcgis Access Token ∙ Found at: https://developers.arcgis.com/documentation/security-and-authentication/reference/access-tokens/ ∙ (last visited: 09-03-2026)
