How to use a limit map in a Scenario
Revision as of 15:40, 17 October 2025 by Maxim@tygron.com (talk | contribs)
How to use a limit map in a Scenario:
  1. Select Current Situation in the ribbon bar
  2. Hover over Overlays, and under Administrative, select Scenario
  3. Activate the Scenario Overlay that was added to the Navigation Panel
  4. Select Multi Scenario in the ribbon bar
  5. Select the Scenario named WADI in the combo box in the ribbon bar to make it the active Scenario.
  6. Select Scenarios in the ribbon bar
  7. Select Scenario WADI
  8. In the Scenario detail panel, adjust the Limit Calculation Scope to Measure Neighborhoods
  9. Verify that the City Plan with WADI is set as Triggered Measure.
  10. Select the tab Limit
  11. Notice the Margin set to 500 and the list of Neighborhoods containing all Neighborhoods.
  12. Inspect Scenario Overlay in the 3D visualization
  13. In the Scenario detail panel, Adjust the Margin to 0.
  14. Notice the list of neighborhoods reduced.
  15. Verify that the Scenario Overlay became smaller as well
  16. Recalculate the Overlays
