API Template usage cheatsheet
Core principles
The Tygron Platform allows for Projects to be used as Templates. Applying them to a new location, carrying over their calculation models and configurations, means its possible to rapidly apply identical analyses. Using the API, this process can be fully automated.
Authentication
Every API call must be accompanied with an appropriate form of authentication
Any url starting with /api/
HTTP Basic Authentication Header
"Authorization: Basic " + base64encode("username@example.com:password")
Any url starting with /api/session/
API token query parameter in url
"/api/session/items/neighborhoods?f=JSON&token=[...]"
Any url starting with /web/
Web token query parameter in url (API token is also allowed)
"/api/web/2dmap.html?f=JSON&token=[...]"
Applying a Template project
To use a template named "demo heat stress" to create a new Project named "my_project", and get its API token for further operations:
Method Parameters Response
POST /api/io/start/?f=JSON ["EDITOR", "demo_heat_stress"] sessionId
POST /api/io/save_project_as/?f=JSON [sessionId, "","my_project",false] Whether succesful
POST /api/io/join/?f=JSON [sessionId, "EDITOR"] json, including apiToken
Generate on new location
To have a new Project become geographically unreferenced, be set to a 2km by km mapsize, and applied to location with latitude 52.080617, longitude 4.312135 (in coordinate system EPSG:4326 ):
Method URL Parameters Response
POST api/session/event/editor/clear_map/?f=JSON [true] n/a
POST /api/session/event/editor/set_initial_map_size/?f=JSON [2000,2000] n/a
POST api/session/event/editor/start_map_creation?f=JSON [52.080617, 4.312135, false, []] n/a
GET /api/session/info/?f=JSON json, including state.
"NORMAL" means generation is done
  • Any Project can be used as a Template, as long as there is no currently running Session, or the Project is set to read-only.
  • All coordinates are x:y, or longitude:latitute. This also includes coordinates in MultiPolygons.
  • To add an Area of Interest, in the "start_map_creation" event replace the empty array with an array of MultiPolygons.
