API Template usage cheatsheet
Revision as of 12:00, 27 March 2025 by Rudolf@tygron.nl (talk | contribs) (Created page with "{{cheatsheet|columns=2| {{cheatsheet-block |title=Core principles |type=description |text= The {{software}} allows for Projects to be used as Templates. Applying them to a new location, carrying over their calculation models and configurations, means its possible to rapidly apply identical analyses. Using the API, this process can be fully automated. |image= |table= }} {{cheatsheet-block |title=Applying a Template project |type=parameters |text...")
Core principles
The Tygron Platform allows for Projects to be used as Templates. Applying them to a new location, carrying over their calculation models and configurations, means its possible to rapidly apply identical analyses. Using the API, this process can be fully automated.
Applying a Template project Root API (/api/)
Any Project can be used as a Template, as long as there is no currently running Session, or the Project is set to read-only.
/api/io/start
['EDITOR', PROJECT_TO_START]
Start a project
