GridSpatial
Revision as of 09:48, 26 March 2025 by Frank@tygron.nl (talk | contribs) (Created page with "thumb|right|300px|Activated measure with a GridSpatial and several buildings on top. A ''GridSpatial'' is a component of a Measure that stores spatial information on how to apply a set of Grids to the DTM when the measure is activated. The area to which the Grids are applied can be restricted by specifying a MultiPolygon to the GridSpatial. This MultiPolygon can either be: * Calculated automatically based on the confi...")
File:Grid measure with buildings.png
A GridSpatial is a component of a Measure that stores spatial information on how to apply a set of Grids to the DTM when the measure is activated. The area to which the Grids are applied can be restricted by specifying a MultiPolygon to the GridSpatial.
  • Calculated automatically based on the configured Grids for that GridSpatial.
  • Configured manually by supplying a MultiPolygon, for example by drawing or importing.
  • You can add more than one Grid to a GridSpatial of a measure.
  • You can manually provide a MultiPolygon to specify where the Grids are applied.
  • No data values in a Grid are never applied to the DTM.
