Foliage height (Shadow Overlay)
Revision as of 11:46, 13 February 2025 by Frank@tygron.nl (talk | contribs) (Created page with "{{Building attributes | <onlyinclude> {{Building attributes|type=row|group=Shadow Overlay |attribute=FOLIAGE_HEIGHT |unit=m |functionvalue= |description=The top height of foliage for a surface geometry described by an Area. |icon= |range=0-100 }} </onlyinclude>}} {{article end |notes= * The Foliage height for an area will be the same for each position in the area. The height is not interpolated as with the Foliage crown factor (Shadow Overlay)|Foliage crown...")
  • The Foliage height for an area will be the same for each position in the area. The height is not interpolated as with the Foliage crown factor.
  • When multiple Areas overlap for a particular grid cell, the Foliage height is averaged.
  • The value must be in the range of 0 and 100 meter.
