Foliage height prequel (Shadow Overlay)
Revision as of 11:42, 13 February 2025 by Frank@tygron.nl (talk | contribs) (Created page with "{{Overlay prequels|overlay=Heat|allowselflinks=true| <onlyinclude>{{Overlay prequels|type=row|overlay=Shadow |prequel=FOLIAGE_HEIGHT |name=Foliage height |unit=m |description=Used for initializing the relative foliage heights. |min=0 |max=100 }}</onlyinclude> }} {{article end |notes=* The values in this prequel grid are clamped between 0m and 100m. No data values are not allowed, although negative no data values will result in a foliage height of 0. * The fo...")
  • The values in this prequel grid are clamped between 0m and 100m. No data values are not allowed, although negative no data values will result in a foliage height of 0.
  • The foliage height is a relative height value in meters. Not the datum height.
