Dates (Shadow Overlay)
Revision as of 09:50, 13 February 2025 by Frank@tygron.nl (talk | contribs) (Created page with "{{Overlay attributes|<onlyinclude> {{Overlay attributes|type=row|overlay=Shadow |attribute=DATES |unit={{time_in_milliseconds}} |description=Dates define the amount of timeframes and are used to define the day and time for calculating sun angles. |icon= |defaultvalue=1375444800000 }}</onlyinclude>}} {{article end |notes= * It is recommended to use the Shadow Overlay Wizard to generate and edit the dates. * The sun altitude and Sun az...")
  • It is recommended to use the Shadow Overlay Wizard to generate and edit the dates.
  • The sun altitude and sun azimuth are (re)calculated automatically based on the project world location and the date, when the dates of the overlay are modified via the Shadow Overlay configuration wizard. They are not automatically recalculated when the dates attribute of the Shadow Overlay is modified directly.
  • The dates are stored as milliseconds past the defined epoch. Care should be taken when manually adjusting these numbers!
