Default floors (Function Value)
Revision as of 14:34, 26 January 2024 by Frank@tygron.nl (talk | contribs)
| Function value | Attribute | Unit | Per category | Range | Description |
| Default floors | DEFAULT_FLOORS | integer | No | 1 to 250 | How many floors a building of this function will have by default, unless otherwise specified. When using this Function as an Action, this is the default amount of floors created, unless the user changes this setting while performing the Action. This values must always be in the range of min floors and max floors (inclusive). |
Values
- The default values for this Function Value are conductive for a generic styling, as well as based expert data consulted in past projects.
- The default values are not overwritten during the creation of a new project.
Used for
- Although the default floors are not overwritten during project creation, sections of buildings can have varying amount of floors based on data found in project sources.
