Brp code (Waterwijzer Overlay)
Revision as of 09:14, 3 October 2023 by Rudolf@tygron.nl (talk | contribs)
BRP Code | Nominal | Crop identification number provided by the Basisregistratie Gewaspercelen (BRP) Source | n/a |
- This parameter is obtained from the Buildings. Projects generated using the Basisregistratie Gewaspercelen (BRP) Source will have this parameter set for the agricultural land use.
- The Waterwijzer tool's API uses this code directly. However, the online tool combines a number of categories together, resulting in a smaller selectable range[1].
- ↑ Koppeltabel landgebruik ∙ Found at: https://waterwijzerlandbouw.wur.nl/downloads/VertalingGewassen-1.1.0.pdf ∙ (last visited: 31-8-2020)
