Setting
Revision as of 13:21, 16 February 2023 by Frank@tygron.nl (talk | contribs)
Setting is an item that stores configuration properties of your project.
List of available settings
Name Default value Description
ACTIVE_SCENARIO 0 Stores the id of the active scenario.
AREA_GROUPS Used to store Area attribute filters
AUTO_CALCULATION true Whether changes made to the project automatically trigger a recalculation of a project.
BASE_PANELS HOVER_PANEL NAVIGATION_PANEL TOPBAR_PANEL LEFT_MENU_PANEL FEEDBACK_PANEL Panels that are considered base panels in the User Interface
CAMERA_SPEED NORMAL Camera Speed (SLOW, NORMAL)
CURRENCY EURO Currency that is used in your project.
CUSTOM_DATA_SERVICE My own CSW service
DECIMALS 6 Decimal accuracy used in attributes and function values
DEFAULT_GROUNDPRICE_M2 400 Default price of one m2 ground in euro
DEFAULT_GROUND_LOWER_PRICE_M3 50 Default price in EUR to lower one m3 ground
DEFAULT_GROUND_RAISE_PRICE_M3 50 Default price in EUR to raise one m3 ground
DETAILED true High detail project.
EXPORT_CRS EPSG:3857 The default export CRS for your project for situations in the Tygron Platform where it currently cannot be selected.
GRID_CELL_SIZE_M 2 Grid cell size in meters, default is 2
IMPORT_CRS The last selected import CRS, selected automatically for files imported into your project in the Tygron Platform
IMPORT_CRS_FORCE_XY true The last selected import "force xy" (=longitude first) option, selected automatically for files imported into your project in the Tygron Platform
LIMIT_MAP MULTIPOLYGON EMPTY The geometry that is used to limit the data obtained during New Project generation.
MAP_SIZE_M 0 0 Map size in X and Y in meters, default 0 (no map)
MAX_TOTAL_GRIDCELLS 0 Used to communicate the maximum amount of grid cells that your project can support.
MEASUREMENT_SYSTEM_TYPE SI The unit system used in the user interface.
MIN_CELL_M 0 Minimum cell size in meters
MODEL_STYLE TEXTURED The model style of the building's in the 3D Visualization.
PROJECT_NAME Project Name The Project's name
RECALCULATION_REQUIRED false A setting that is set by the Tygron Platform to indicate this project required a recalculation.
RECENT_CRSS EPSG:3857 EPSG:28992 A list of CRS's that have been used while editing your project. Shows in the "recently used" part of the crs selection panel.
REGION NORTHWESTERN_EUROPE Stores the Region your project is situated in. Can be overwritten using this setting.
RESERVED_LAND MULTIPOLYGON EMPTY Setting that stores the geometries of plots that are currently in transition of ownership.
SATELLITE_BRIGHTNESS -1
SATELLITE_COLOR
SATELLITE_FILE_NAME default
SCHEDULED_UPDATE
SCHEDULED_UPDATE_MAIL
SCHEDULED_UPDATE_SMS
SDK_ACCESS false Currently not used
SECTOR_SIZE_M 500 The width and height size of a Height sector in meters.
SHOW_ACTION_LOG true
SHOW_BUILDING_AND_MEASURE_POPUP false
SHOW_WATER_POPUP false
SKY_TYPE DEFAULT
SOLAR_PANEL_POSITION 0.0 -0.5 -1.0
STATE NOTHING
SUN_DATES
SUPER_USER_MESSAGE
SURROUNDING_MAP_EXTEND_M 0 0
TIMESTAMP_FORMAT dd/MM HH:mm:ss
TIME_ZONE
TRAFFIC_VISUAL_MULTIPLIER 4.0
WATER_HEIGHT -20000.0
WATER_TYPE CANAL
WEB_ALLOW_LOGIC_EVENT true
WEB_ALLOW_PARTICIPANT_EVENT true
WEB_ALLOW_QUERIES false
WEB_BASE_MAP SATELLITE
WEB_FRONT_PANEL -1
WEB_MAP_CUSTOM_PANEL -1
WIND_DIRECTION 135
WIND_SPEED_M_PER_S 5.0
WIZARD_TIME_MINUTES -1
WORLD_REFERENCE_POINT 0 0
