Setting
Revision as of 13:20, 16 February 2023 by Frank@tygron.nl (talk | contribs)
Setting is an item that stores configuration properties of your project.
List of available settings
Name | Default value | Description |
<spa> id="ACTIVE_SCENARIO"> ACTIVE_SCENARIO | 0 | Stores the id of the active scenario. |
AREA_GROUPS | Used to store Area attribute filters | |
AUTO_CALCULATION | true | Whether changes made to the project automatically trigger a recalculation of a project. |
BASE_PANELS | HOVER_PANEL NAVIGATION_PANEL TOPBAR_PANEL LEFT_MENU_PANEL FEEDBACK_PANEL | Panels that are considered base panels in the User Interface |
CAMERA_SPEED | NORMAL | Camera Speed (SLOW, NORMAL) |
CURRENCY | EURO | Currency that is used in your project. |
CUSTOM_DATA_SERVICE CUSTOM_DATA_SERVICE | My own CSW service | |
DECIMALS | 6 | Decimal accuracy used in attributes and function values |
DEFAULT_GROUNDPRICE_M2 | 400 | Default price of one m2 ground in euro |
DEFAULT_GROUND_LOWER_PRICE_M3 | 50 | Default price in EUR to lower one m3 ground |
DEFAULT_GROUND_RAISE_PRICE_M3 | 50 | Default price in EUR to raise one m3 ground |
DETAILED | true | High detail project. |
EXPORT_CRS | EPSG:3857 | The default export CRS for your project for situations in the Tygron Platform where it currently cannot be selected. |
GRID_CELL_SIZE_M | 2 | Grid cell size in meters, default is 2 |
IMPORT_CRS | The last selected import CRS, selected automatically for files imported into your project in the Tygron Platform | |
IMPORT_CRS_FORCE_XY | true | The last selected import "force xy" (=longitude first) option, selected automatically for files imported into your project in the Tygron Platform |
LIMIT_MAP | MULTIPOLYGON EMPTY | The geometry that is used to limit the data obtained during New Project generation. |
MAP_SIZE_M | 0 0 | Map size in X and Y in meters, default 0 (no map) |
MAX_TOTAL_GRIDCELLS | 0 | Used to communicate the maximum amount of grid cells that your project can support. |
MEASUREMENT_SYSTEM_TYPE | SI | The unit system used in the user interface. |
MIN_CELL_M | 0 | Minimum cell size in meters |
MODEL_STYLE | TEXTURED | The model style of the building's in the 3D Visualization. |
PROJECT_NAME | Project Name | The Project's name |
RECALCULATION_REQUIRED | false | A setting that is set by the Tygron Platform to indicate this project required a recalculation. |
RECENT_CRSS | EPSG:3857 EPSG:28992 | A list of CRS's that have been used while editing your project. Shows in the "recently used" part of the crs selection panel. |
REGION | NORTHWESTERN_EUROPE | Stores the Region your project is situated in. Can be overwritten using this setting. |
RESERVED_LAND | MULTIPOLYGON EMPTY | Setting that stores the geometries of plots that are currently in transition of ownership. |
SATELLITE_BRIGHTNESS | -1 | |
SATELLITE_COLOR | ||
SATELLITE_FILE_NAME | default | |
SCHEDULED_UPDATE | ||
SCHEDULED_UPDATE_MAIL | ||
SCHEDULED_UPDATE_SMS | ||
SDK_ACCESS | false | Currently not used |
SECTOR_SIZE_M | 500 | The width and height size of a Height sector in meters. |
SHOW_BUILDING_AND_MEASURE_POPUPSHOW_BUILDING_AND_MEASURE_POPUP | true | |
SHOW_BUILDING_AND_MEASURE_POPUP | false | |
SHOW_WATER_POPUP | false | |
SKY_TYPE | DEFAULT | |
SOLAR_PANEL_POSITION | 0.0 -0.5 -1.0 | |
STATE | NOTHING | |
SUN_DATES | ||
SUPER_USER_MESSAGE | ||
SURROUNDING_MAP_EXTEND_M | 0 0 | |
TIMESTAMP_FORMAT | dd/MM HH:mm:ss | |
TIME_ZONE | ||
TRAFFIC_VISUAL_MULTIPLIER | 4.0 | |
WATER_HEIGHT | -20000.0 | |
WATER_TYPE | CANAL | |
WEB_ALLOW_LOGIC_EVENT | true | |
WEB_ALLOW_PARTICIPANT_EVENT | true | |
WEB_ALLOW_QUERIES | false | |
WEB_BASE_MAP | SATELLITE | |
WEB_FRONT_PANEL | -1 | |
WEB_MAP_CUSTOM_PANEL | -1 | |
WIND_DIRECTION | 135 | |
WIND_SPEED_M_PER_S | 5.0 | |
WIZARD_TIME_MINUTES | -1 | |
WORLD_REFERENCE_POINT | 0 0 |
