Setting
Revision as of 13:15, 16 February 2023 by Frank@tygron.nl (talk | contribs) (→List of available settings)
Setting is an item that stores configuration properties of your project.
| Name | Default value | Description |
| id="ACTIVE_SCENARIO" ACTIVE_SCENARIO | 0 | Stores the id of the active scenario. |
| id="AREA_GROUPS" AREA_GROUPS | Used to store Area attribute filters | |
| id="AUTO_CALCULATION" AUTO_CALCULATION | true | Whether changes made to the project automatically trigger a recalculation of a project. |
| id="BASE_PANELS" BASE_PANELS | HOVER_PANEL NAVIGATION_PANEL TOPBAR_PANEL LEFT_MENU_PANEL FEEDBACK_PANEL | Panels that are considered base panels in the User Interface |
| id="CAMERA_SPEED" CAMERA_SPEED | NORMAL | Camera Speed (SLOW, NORMAL) |
| id="CURRENCY" CURRENCY | EURO | Currency that is used in your project. |
| id="CUSTOM_DATA_SERVICE" CUSTOM_DATA_SERVICE | My own CSW service | |
| id="DECIMALS" DECIMALS | 6 | Decimal accuracy used in attributes and function values |
| id="DEFAULT_GROUNDPRICE_M2" DEFAULT_GROUNDPRICE_M2 | 400 | Default price of one m2 ground in euro |
| id="DEFAULT_GROUND_LOWER_PRICE_M3" DEFAULT_GROUND_LOWER_PRICE_M3 | 50 | Default price in EUR to lower one m3 ground |
| id="DEFAULT_GROUND_RAISE_PRICE_M3" DEFAULT_GROUND_RAISE_PRICE_M3 | 50 | Default price in EUR to raise one m3 ground |
| id="DETAILED" DETAILED | true | High detail project. |
| id="EXPORT_CRS" EXPORT_CRS | EPSG:3857 | The default export CRS for your project for situations in the Tygron Platform where it currently cannot be selected. |
| id="GRID_CELL_SIZE_M" GRID_CELL_SIZE_M | 2 | Grid cell size in meters, default is 2 |
| id="IMPORT_CRS" IMPORT_CRS | The last selected import CRS, selected automatically for files imported into your project in the Tygron Platform | |
| id="IMPORT_CRS_FORCE_XY" IMPORT_CRS_FORCE_XY | true | The last selected import "force xy" (=longitude first) option, selected automatically for files imported into your project in the Tygron Platform |
| id="LIMIT_MAP" LIMIT_MAP | MULTIPOLYGON EMPTY | The geometry that is used to limit the data obtained during New Project generation. |
| id="MAP_SIZE_M" MAP_SIZE_M | 0 0 | Map size in X and Y in meters, default 0 (no map) |
| id="MAX_TOTAL_GRIDCELLS" MAX_TOTAL_GRIDCELLS | 0 | Used to communicate the maximum amount of grid cells that your project can support. |
| id="MEASUREMENT_SYSTEM_TYPE" MEASUREMENT_SYSTEM_TYPE | SI | The unit system used in the user interface. |
| id="MIN_CELL_M" MIN_CELL_M | 0 | Minimum cell size in meters |
| id="MODEL_STYLE" MODEL_STYLE | TEXTURED | The model style of the building's in the 3D Visualization. |
| id="PROJECT_NAME" PROJECT_NAME | Project Name | The Project's name |
| id="RECALCULATION_REQUIRED" RECALCULATION_REQUIRED | false | A setting that is set by the Tygron Platform to indicate this project required a recalculation. |
| id="RECENT_CRSS" RECENT_CRSS | EPSG:3857 EPSG:28992 | A list of CRS's that have been used while editing your project. Shows in the "recently used" part of the crs selection panel. |
| id="REGION" REGION | NORTHWESTERN_EUROPE | Stores the Region your project is situated in. Can be overwritten using this setting. |
| id="RESERVED_LAND" RESERVED_LAND | MULTIPOLYGON EMPTY | Setting that stores the geometries of plots that are currently in transition of ownership. |
| id="SATELLITE_BRIGHTNESS" SATELLITE_BRIGHTNESS | -1 | |
| id="SATELLITE_COLOR" SATELLITE_COLOR | ||
| id="SATELLITE_FILE_NAME" SATELLITE_FILE_NAME | default | |
| id="SCHEDULED_UPDATE" SCHEDULED_UPDATE | ||
| id="SCHEDULED_UPDATE_MAIL" SCHEDULED_UPDATE_MAIL | ||
| id="SCHEDULED_UPDATE_SMS" SCHEDULED_UPDATE_SMS | ||
| id="SDK_ACCESS" SDK_ACCESS | false | Currently not used |
| id="SECTOR_SIZE_M" SECTOR_SIZE_M | 500 | The width and height size of a Height sector in meters. |
| id="SHOW_ACTION_LOG" SHOW_ACTION_LOG | true | |
| id="SHOW_BUILDING_AND_MEASURE_POPUP" SHOW_BUILDING_AND_MEASURE_POPUP | false | |
| id="SHOW_WATER_POPUP" SHOW_WATER_POPUP | false | |
| id="SKY_TYPE" SKY_TYPE | DEFAULT | |
| id="SOLAR_PANEL_POSITION" SOLAR_PANEL_POSITION | 0.0 -0.5 -1.0 | |
| id="STATE" STATE | NOTHING | |
| id="SUN_DATES" SUN_DATES | ||
| id="SUPER_USER_MESSAGE" SUPER_USER_MESSAGE | ||
| id="SURROUNDING_MAP_EXTEND_M" SURROUNDING_MAP_EXTEND_M | 0 0 | |
| id="TIMESTAMP_FORMAT" TIMESTAMP_FORMAT | dd/MM HH:mm:ss | |
| id="TIME_ZONE" TIME_ZONE | ||
| id="TRAFFIC_VISUAL_MULTIPLIER" TRAFFIC_VISUAL_MULTIPLIER | 4.0 | |
| id="WATER_HEIGHT" WATER_HEIGHT | -20000.0 | |
| id="WATER_TYPE" WATER_TYPE | CANAL | |
| id="WEB_ALLOW_LOGIC_EVENT" WEB_ALLOW_LOGIC_EVENT | true | |
| id="WEB_ALLOW_PARTICIPANT_EVENT" WEB_ALLOW_PARTICIPANT_EVENT | true | |
| id="WEB_ALLOW_QUERIES" WEB_ALLOW_QUERIES | false | |
| id="WEB_BASE_MAP" WEB_BASE_MAP | SATELLITE | |
| id="WEB_FRONT_PANEL" WEB_FRONT_PANEL | -1 | |
| id="WEB_MAP_CUSTOM_PANEL" WEB_MAP_CUSTOM_PANEL | -1 | |
| id="WIND_DIRECTION" WIND_DIRECTION | 135 | |
| id="WIND_SPEED_M_PER_S" WIND_SPEED_M_PER_S | 5.0 | |
| id="WIZARD_TIME_MINUTES" WIZARD_TIME_MINUTES | -1 | |
| id="WORLD_REFERENCE_POINT" WORLD_REFERENCE_POINT | 0 0 |
