How to add a GeoTIFF to a measure
Revision as of 15:36, 11 January 2023 by Frank@tygron.nl (talk | contribs)
How to add a GeoTIFF to a measure:
  1. Add a measure and select it.
  2. In the lower left of the interface, click on the button Add Tiff Spatial.
  3. Move to the Tiff Spatial detail panel in the right of the interface and click the Add Tiff button.
  4. The GeoTIFF selection panel now opens.
  5. If you want to import new GeoTIFFs from your computer or from the GeoShare, you can now do so.
  6. Once done importing, select one, or more GeoTIFFs by holding CTRL or SHIFT while clicking, and confirm.
  7. The selected GeoTIFFs should now show up in the Tiff Spatial detail panel.
  8. Notice the checkbox below named "Calculate Area from Tiffs automatically".
  9. If you want to manually restrict the area where this Tiff Spatial is applied to, uncheck this option. Next,click on the button below the checkbox to manually draw an area for the Tiff Spatial. The Tiff Spatial 's GeoTIFFs will only be applied for that area when activating this measure.
  10. Otherwise, the MultiPolygon for the Tiff Spatial is automatically calculated by the Tygron Platform once the GeoTIFF changes are send to the server. This calculation might take a while depending on the amount and complexity of GeoTIFFs supplied.
  • You can add more than one GeoTIFF to a TiffSpatial of a measure.
  • You can manually provide the MultiPolygon for which the GeoTIFFs are applied.
