How to add and remove an action menu
Revision as of 15:55, 21 October 2022 by Frank@tygron.nl (talk | contribs) (Order)
Editor → Future Design (Ribbon tab) → Actions (Ribbon bar)
The left panel in the editor, when editing the actions.
To add an action to a stakeholder, the stakeholder first needs to have at least one menu to place the action in. It is not possible to add an action to a stakeholder without organizing it into a menu. A menu without actions will appear to a user as empty, and does not directly serve any purpose.
How to add an action menu:
  1. Select "Stakeholders" in the ribbon header.
  2. Select "Actions" in the ribbon bar.
  3. Select "Add" in the left panel.
How to remove an action menu:
  3. Select the menu you wish to remove.
  4. Select "Remove" in the left panel.
Order
The buttons with which to alter the "order" of the menus.
The menu order defines the order in which the menus are being presented to the user. You can change the order by selecting a menu and pressing "Up" and "Down".
