How to add, remove and duplicate
Revision as of 14:10, 21 October 2022 by Frank@tygron.nl (talk | contribs) (Created page with "{{Editor location|Stakeholders}} ===Adding stakeholders=== In the editor, new stakeholders can be added to your project in two ways: using the ribbon bar dropdown menu, or using the left panel ====Adding stakeholders using the ribbon bar dropdown menu==== 150px|thumb|left|The ribbon bar dropdown menu {{Editor steps|title=add a new stakeholder using the ribbon bar dropdown menu|Select "Multi stakeholder" in the ribbon header.|Select "Stak...")
Editor → Multi Scenario (Ribbon tab) → Stakeholders (Ribbon bar)
Adding stakeholders
How to add a new stakeholder using the ribbon bar dropdown menu:
  1. Select "Multi stakeholder" in the ribbon header.
  2. Select "Stakeholders" in the ribbon bar.
  3. Select "Add..." from the dropdown menu.
Adding stakeholders using the left panel
How to add a new stakeholder using the left panel:
  3. Select "Add" from the bottom of the left panel
  4. An "Inhabitants" Stakeholder is added to the list.
Removing and Duplicating stakeholders using the left panel
How to duplicate a stakeholder using the left panel:
  3. Select an existing stakeholder in your project in the left panel
  4. Select "Duplicate" from the bottom of the left panel
  5. The selected stakeholder is duplicated and added to the list.
How to remove a stakeholder using the left panel:
  4. Select "Remove" from the bottom of the left panel
  5. The selected stakeholder is removed from your project.
