How to add and remove Event Bundles
Revision as of 14:07, 7 October 2022 by Frank@tygron.nl (talk | contribs)
The Left Panel allows you to add, remove, and select event bundles.
You can create (empty) event bundles, which events can then be added to. An event bundle which does not contain events can be used as any other event bundle, but will have no effects.
How to add an event bundle:
- In the ribbon header, select "Stakeholders".
- In the ribbon bar, select "Event Bundles".
- In the left panel, select "Add".
How to duplicate an event bundle:
- In the left panel, select the event bundle you wish to duplicate.
- In the left panel, select "Duplicate".
How to remove an event bundle:
- In the left panel, select the event bundle you wish to remove.
- In the left panel, select "Remove".
