How to change properties of a Scenario
Revision as of 11:27, 6 October 2022 by Frank@tygron.nl (talk | contribs) (Created page with "==Changing the properties of a Scenario== {{Editor location|Scenario}} ===Scenario=== By selecting a scenario entry on the left panel, the following properties become available on the right panel: frame|left|Scenarios ([[Left Panel|left panel)]] ====Name==== frame|right|Enter the scenario name here ([[Right Panel|right panel)]] : In the Name field a more suitable name can be entered, if desired. Examples of this c...")
Editor → Multi Scenario (Ribbon tab) → Scenario (Ribbon bar) → The Scenario to edit (Left panel)
Scenario
Scenarios (left panel)
Name
Enter the scenario name here (right panel)
In the Name field a more suitable name can be entered, if desired. Examples of this can be: "Tutorial", "Prologue", etc.
Template:Editor steps
Description
Describe the scenario (right panel)
The description field allows for describing the scenario in the Editor. This is convenient when the scenario has added complexity.
