How to add or remove a Scenario
Revision as of 11:24, 6 October 2022 by Frank@tygron.nl (talk | contribs) (Created page with "{{Editor location|scenarios}} ====Adding a Scenario==== A scenario can be added in two ways in the {{software}}; through a ribbon drop down option or by selecting the Add button on the bottom of the left panel, after selecting scenarios in the ribbon bar. {{Editor steps|title=add scenario to a project|Select Multi-Scenario → Scenarios|Select Add new Scenario from the drop down menu|Or select Add on the bottom of the scenario panel}} <br clear=all>")
Editor → Multi Scenario (Ribbon tab) → Scenario (Ribbon bar)
Adding a Scenario
A scenario can be added in two ways in the Tygron Platform; through a ribbon drop down option or by selecting the Add button on the bottom of the left panel, after selecting scenarios in the ribbon bar. Template:Editor steps
