How to edit measure events
Revision as of 11:58, 5 October 2022 by Frank@tygron.nl (talk | contribs) (Created page with "{{Editor location|measure events}} frame|left|The right panel allows you to edit events of a [[measure.]] ====Event lists==== frame|right|The dropdown to switch between lists of events.''Measures have 4 distinct lists of events. Each list is related to a different state of the measure. When the measure reaches one of the following states, the related list of events will be triggered:'' *...")
Editor → Future Design (Ribbon tab) → Measures (Ribbon bar) → The Measure to edit (Left panel) → Events (Sub-option)
The right panel allows you to edit events of a measure.
Event lists
- Measure construction planned
- Measure construction cancelled
- Measure construction started
- Measure construction finished
The right panel allows you to switch between the lists of events connected to the measure.
Adding, removing, and editing events
