How to edit measure cost details
Revision as of 11:53, 5 October 2022 by Frank@tygron.nl (talk | contribs) (Created page with "{{Editor location|measure costs}} frame|left|The right panel allows you to edit properties. ====Construction Time==== frame|right|The field for the "construction time". : ''The construction time in months. You can change this by altering the number in the "construction time" field.''<br clear=right> ====Demolition Time==== File:measures-right-cost-demotime.jpg|frame|right|The field for the "dem...")
Editor → Future Design (Ribbon tab) → Measures (Ribbon bar) → The Measure to edit (Left panel) → Cost Details (Sub-option)
Construction Time
- The construction time in months. You can change this by altering the number in the "construction time" field.
Demolition Time
The field for the "demolition time".
- The demolition time in months. You can change this by altering the number in the "demolition time" field.
Construction cost
- The construction cost. This is the impact the measure will have on the enacting stakeholder's budget when the measure is enacted. This cost is in addition to any costs brought forth by spatial aspects of the measure, such as the placement of buildings. The cost type can be set to the following values:
- NONE (No additional costs)
- FIXED (A fixed additonal cost)
- VOLUME (An additional cost based on the area/volume of the spatial aspects of the measure)
- You can change this by selecting the desired cost type using the dropdown, and entering or changing the number in the field below it.
Demolition cost
The field for the "demolition cost".
- The demolition cost. This is the impact the measure will have on the enacting stakeholder's budget when the measure is demolished. This cost is in addition to any costs brought forth by spatial aspects of the measure, such as the placement of buildings. The cost type can be set to the following values:
