Traffic NO2 formula (Traffic NO2 Overlay)
The calculations follow the standard rekenmethode 1 (SRM 1).
Cjm[NO2]=Ca,jm[NO2]+Cb,jm[NO2]
Cjm[NO2] = annual average concentration [μg/m3],
Ca,jm[NO2] = annual average background-concentration (default = 0 [μg/m3], can be adjusted via the overlay attributes),
Cb,jm[NO2] = annual average traffic contribution to NO2 concentration [μg/m3].
Contribution NO2
To compute the annual average traffic contribution to NO2, Cb,jm[NO2] [μg/m3], the following formula from SRM1 is applied:
Cb,jm[NO2]=fNO2Cb,jm[NOx]+BCa,jm[O3]Cb,jm[NOx](1fNO2)Cb,jm[NOx](1Fno2)+K
Cb,jm[NOx] = annual average traffic contribution to NOx concentration [μg/m3],
Cb,jm[O3] = annual average concentration ozon [μg/m3] (default = 42),
fNO2 = weighted fraction direct emitted NO2 [-],
B = parameter (default 0.6),
K = parameter for conversion NO to NO2 (default = 100 μg/m3).
Contribution NOX
To compute the annual average traffic contribution to NOX, Cb,jm[NOX] [μg/m3], the following formula from SRM1 is applied:
Cb,jm[NOx]=FkENOxθFbFmeteo
Fk = calibration factor [-] (default = 0.62]
ENOx = emission number NOx [μg/m/s]
θ = dilution factor [-]
Fb = tree factor (default = 1)
Fmeteo = 5/windspeed. Default value for windspeed is 5 m/s
The computation of the dilution factor, θ, is split into two situations.
For surrounding cells within a distance of 30m:
θ=aS2+bS+c
And for cells within a distance of 30-60m (for road-type 1 only):
θ=αSp
S = the calculation distance
a = configurable using model attribute: ROAD1_30M_A
b = configurable using model attribute: ROAD1_30M_B
c = configurable using model attribute: ROAD1_30M_C
α = configurable using model attribute: ROAD1_60M_ALPHA
p = configurable using model attribute: ROAD1_60M_POWER
The weighted fraction of direct emitted NO2 [-] is computed as:
fNO2=ENO2ENOx
ENO2 = emission number NOs [μg/m/s]
Tree Factor
The tree factor is calculated as followed:
Fb=1+t2At
At=πd2Ac
Fb = Tree factor, value between 1 and 1.5,
t = Amount of tree cells within the search distance,
At = Search area measured in amount of cells,
d = Search distance of trees, currently set on 30 meters,
Ac = Grid cell area in square meters.
Emission numbers
The emission numbers (E) for both NOx and NO2 are computed as:
Edrive=(1.0jc)ncEc,d+(1.0jv)nvEv+(1.0jt)ntEt+(1.0jb)nbEb Ejam=(jc)ncEc,j+jvnvEv,j+jtntEt,j+jbbtEb,j E=(Edrive+Ejam)1000(243600)
E = Calculated emission of either NOx or NO2
Edrive = Calculated emission of driving traffic of either NOx or NO2.
Ejam = Calculated emission of jammed traffic of either NOx or NO2.
Ec,d = Calculated emission of driving cars, hourly or daily.
Ev,d = Calculated emission of driving vans, hourly or daily.
Et,d = Calculated emission of driving trucks, hourly or daily.
Eb,d = Calculated emission of driving buses, hourly or daily.
Ec,j = Calculated emission of jammed cars, hourly or daily.
Ev,j = Calculated emission of jammed vans, hourly or daily.
Et,j = Calculated emission of jammed trucks, hourly or daily.
Eb,j = Calculated emission of jammed buses, hourly or daily.
nc = number of car traffic, hourly or daily value.
nv = number of van traffic, hourly or daily value.
nt = number of truck traffic, hourly or daily value.
nb = number of bus traffic, hourly or daily value.
jc = fraction of car traffic in traffic jams.
jv = fraction of van traffic in traffic jams.
jt = fraction of truck traffic in traffic jams.
jb = fraction of bus traffic in traffic jams.
  • N = traffic intensity [units per day]
  • fm = fraction vans [-]
  • fz = fraction trucks [-]
  • fb = fraction buses [-]
  • El = emission value cars [g/km]
  • Em = emission value vans [g/km]
  • Ez = emission value trucks [g/km]
  • Eb = emission value buses [g/km]
  • FS = fraction congested traffic [-]
  • E*,d = emission factor per class (cars, vans, trucks or buses) if congested
  • If the traffic amount is defined as a single value, that value is used for all defined hours. However, if the amount if an array of values, each of the 24 indexes of that array are assumed to correspond to the hour denoted by those indexes, and as such that specific value from the array is used.
  • The SRM1[1] calculation method is only applicable for urban environments.
  1. SRM1 ∙ Regeling beoordeling luchtkwaliteit 2007, Bijlage I ∙ Found at: http://wetten.overheid.nl/BWBR0022817/2013-01-01#Bijlage1 ∙ (last visited: 16-02-2022)
