Relation (TQL)
Relation is a TQL Clause that can basically switch the subject of a TQL request to an other one, which is related to the original subject.
Clause As a polygon As an item Type
RELATION N/A Rather than data of the specified item, use the item which has this relation to it. Technical name indicating a type of relation.
Relation Types
Relation type
OWNER
CONSTRUCTOR
DEMOLISHER
PERMITTER
SENDER
RECEIVER
NETOWNER
BORDER_A
BORDER_B
BUILDING
Implemented Relations
Item type Relation Type Description
BUILDING OWNER, CONSTRUCTOR The Stakeholder configured as the owner of Building
BUILDING DEMOLISHER The Stakeholder configured as demolisher of Building
MEASURE BUILDING The first Building configured for this Measure
MEASURE OWNER The Stakeholder configured as the owner of this Measure
NET_CLUSTER OWNER The Stakeholder configured as the owner of this Net Cluster
NET_CLUSTER NETOWNER The Stakeholder configured as the owner of the Net Type of the first Net Load, configured as a Net Setting.
NET_LOAD OWNER The Stakeholder configured as the owner of this Net Cluster.
NET_LOAD NETOWNER The Stakeholder configured as the owner of the Net Type, configured as a Net Setting.
NET_LOAD BUILDING The Building configured for this Net Load.
PANEL OWNER The Stakeholder configured as the owner of this Panel.
Zone PERMITTER The Stakeholder configured as the permitter of this Zone. Often the Municipality by default.
Areas allow any of the relations to be configured using the editor area api events ADD_RELATION, SET_RELATION and REMOVE_RELATIONS.
