Relation (TQL)
Revision as of 14:16, 1 March 2022 by Frank@tygron.nl (talk | contribs)
| Clause | As a polygon | As an item | Type |
| RELATION | N/A | Rather than data of the specified item, use the item which has this relation to it. | Technical name indicating a type of relation. |
Relation Types
| Relation type |
| OWNER |
| CONSTRUCTOR |
| DEMOLISHER |
| PERMITTER |
| SENDER |
| RECEIVER |
| NETOWNER |
| BORDER_A |
| BORDER_B |
| BUILDING |
Implemented Relations
| Item type | Relation Type | Description |
| BUILDING | OWNER, CONSTRUCTOR | The Stakeholder configured as the owner of Building |
| BUILDING | DEMOLISHER | The Stakeholder configured as demolisher of Building |
| MEASURE | BUILDING | The first Building configured for this Measure |
| MEASURE | OWNER | The Stakeholder configured as the owner of this Measure |
| NET_CLUSTER | OWNER | The Stakeholder configured as the owner of this Net Cluster |
| NET_CLUSTER | NETOWNER | The Stakeholder configured as the owner of the Net Type of the first Net Load, configured as a Net Setting. |
| NET_LOAD | OWNER | The Stakeholder configured as the owner of this Net Cluster. |
| NET_LOAD | NETOWNER | The Stakeholder configured as the owner of the Net Type, configured as a Net Setting. |
| NET_LOAD | BUILDING | The Building configured for this Net Load. |
| PANEL | OWNER | The Stakeholder configured as the owner of this Panel. |
| Zone | PERMITTER | The Stakeholder configured as the permitter of this Zone. Often the Municipality by default. |
Areas allow any of the relations to be configured using the editor area api events ADD_RELATION, SET_RELATION and REMOVE_RELATIONS.
