Relation (TQL)
Revision as of 13:59, 1 March 2022 by Frank@tygron.nl (talk | contribs) (Created page with "{| class="wikitable" |- ! Clause ! As a polygon ! As an item ! Type |- | RELATION | OWNER, CONSTRUCTOR, DEMOLISHER, PERMITTER, SENDER, RECEIVER, NETOWNER, BORDER_A, BORDER_B,...")
Clause As a polygon As an item Type
RELATION OWNER, CONSTRUCTOR, DEMOLISHER, PERMITTER, SENDER, RECEIVER, NETOWNER, BORDER_A, BORDER_B, BUILDING Rather than data of the specified item, use the item which has this relation to it. Technical name indicating a type of relation.
Implemented Relations
Item type Relation Type Description
BUILDING OWNER, CONSTRUCTOR The Stakeholder configured as the owner of Building - BUILDING DEMOLISHER The Stakeholder configured as demolisher of Building - MEASURE BUILDING The first Building configured for this Measure - MEASURE OWNER The Stakeholder configured as the owner of this Measure - NET_CLUSTER OWNER The Stakeholder configured as the owner of this Net Cluster - NET_CLUSTER NETOWNER The Stakeholder configured as the owner of the Net Type of the first Net Load, configured as a Net Setting. - NET_LOAD OWNER The Stakeholder configured as the owner of this Net Cluster. - NET_LOAD NETOWNER The Stakeholder configured as the owner of the Net Type, configured as a Net Setting. - NET_LOAD BUILDING The Building configured for this Net Load. - PANEL OWNER The Stakeholder configured as the owner of this Panel. - Zone PERMITTER The Stakeholder configured as the permitter of this Zone. Often the Municipality by default. -
Areas allow any of the relations to be configured using the api events ADD_RELATION, SET_RELATION and REMOVE_RELATIONS.
