Low ground water prequel (Subsidence Overlay)
Revision as of 16:48, 10 February 2022 by Frank@tygron.nl (talk | contribs) (Frank@tygron.nl moved page Low ground water level prequel (Subsidence Overlay) to Low ground water prequel (Subsidence Overlay))
The initial low groundwater level in the Subsidence Module at the start of the simulation can be initialized using a GeoTIFF.
In the Subsidence Overlay Wizard it is possible to select one of the Default datasets provided, to import a GeoTIFF or to do nothing and proceed with the next step.
| Low Groundwater GeoTIFF specification | |||||||||
| Description | The depth of the ground water level, relative to the surface. | ||||||||
| Value | Low Groundwater level (m below terrain height) | ||||||||
Default data
For the Netherlands, a number of groundwater GeoTIFFs are provided by default, based on data provided by The Netherlands Hydrological Instrumentarium:
- NL_GHG_kk-nhi (Average highest watertable)
- NL_GLG_kk-nhi (Average lowest watertable)
- NL_GVG_kk-nhi (Average spring watertable)
- When no GeoTIFF is selected or imported, the water levels of groundwater level areas are used to initialize groundwater levels.
