Ground water level area (Subsidence Overlay)
Revision as of 09:49, 16 February 2021 by Frank@tygron.nl (talk | contribs)
Ground water level areas are areas which can be used to define the initial ground water level, when detailed raster data of ground water depths is not available.
HI_GROUND_WATER_LEVEL | m + datum | The yearly high (average) ground water level in this area. Note that this is the ground water level (datum), not the ground water depth. | n/a | |
LOW_GROUND_WATER_LEVEL | m + datum | The yearly low (average) ground water level in this area. Note that this is the ground water level (datum), not the ground water depth. | n/a |
- Water level areas and subsidence areas can also be ground water level areas at the same time.
