Subsidence area (Subsidence Overlay)
Revision as of 09:42, 16 February 2021 by Frank@tygron.nl (talk | contribs) (Created page with "Subsidence areas are conceptual areas which allow users to override subsidence related attributes of the Terrain (Subsidence Overlay...")
Subsidence areas are conceptual areas which allow users to override subsidence related attributes of the underlying terrain.
SUBSIDENCE | boolean | Whether or not subsidence should be calculated for a terrain or in a given area. Subsidence is calculated when the value is not equal to 0. | false | |
CLAY_THICKNESS | m | The thickness of the clay layer on the peat, for the calculation of the oxidation component of subsidence. | 0.2 | |
PEAT_FRACTION | The fraction of the soil composed of peat, for the calculation of the compaction component of subsidence. | 0.4 | ||
TOPLAYER_THICKNESS | m | The thickness of the layer covering the peat, for the calculation of the compaction component of subsidence. | 1.2 |
- Clay thickness defined in a Subsidence area is ignored when a clay thickness geotiff is used.
