Water area (Subsidence Overlay)
Revision as of 13:26, 10 February 2021 by Frank@tygron.nl (talk | contribs)
Water level areas are areas of which the water level is managed by a water authority. Water levels have to be kept high enough such that subsidence is minimized but low enough such that agriculture can flourish. When subsidence occurs, the subsidence model supports the mechanism of indexation in which water levels are automatically lowered to keep the ground water levels at a similar level. The subsidence terrain keys can all be overridden by overlapping Water level Areas.
WATER_LEVEL | m + datum | The datum height of the water level in the Water Area. | n/a | |
CLAY_THICKNESS | m | The thickness of the clay layer on the peat, for the calculation of the oxidation component of subsidence. | 0.2 | |
PEAT_FRACTION | The fraction of the soil composed of peat, for the calculation of the compaction component of subsidence. | 0.4 | ||
TOPLAYER_THICKNESS | m | The thickness of the layer covering the peat, for the calculation of the compaction component of subsidence. | 1.2 | |
SUBSIDENCE | boolean | Whether or not subsidence should be calculated for a terrain or in a given area. Subsidence is calculated when the value is not equal to 0. | false | |
INDEXATION | m | When Indexation is non zero, the water level is automatically adjusted each simulation year, depending on the calculated subsidence. Indexation may range from 0 (0%) to 1 (100%). | 10.7 | |
WATER_LEVEL_OUTPUT | m + datum | The new datum height of the water level in the Water Area as a result of indexation in response to subsidence. | n/a |
- In the subsidence models, water levels of water areas only influence the ground water level indirectly. Automatic adjustments of water levels, by indexation, do not always lower the ground water level in the same amount.
