Drainage feature (Subsidence Overlay)
Revision as of 10:47, 10 February 2021 by Frank@tygron.nl (talk | contribs)
  • A drainage is active when the Drainage value is larger than 0. In this case, the drainage always sets the ground water level to the same relative depth. The drainage value indicates the relative depth of the ground water.
  • A drainage is passive when the Drainage value is smaller than 0. In this case, the water level is additionally adjustmented by the high or low passive drainage value configured for the Subsidence Overlay. In this case, the actual negative value of the drainage does not matter.
