Compaction formula (Subsidence Overlay)
Revision as of 16:48, 8 February 2021 by Frank@tygron.nl (talk | contribs)
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle S_{sub} = ( a_{peat} \cdot p_{x,y} + a_{tl} \cdot tl_{x,y} ) \cdot log10(t_{days}) + a_h \cdot \Delta{h} + b_p \cdot p_{x,y} + b_{tl} \cdot tl_{x,y}}
where
  • is the peat fraction of the cell at coordinate (x,y)
  • Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle tl_{x,y}} is the top layer thickness of the cell at coordinate (x,y)
  • Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle \Delta_h} The height increase as a result of the actions taken during a session, such as the creation of levees.
  • Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle t_{days}} is the number of days in a year times the current year being calculated.
  • Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle a_{peat}} is the first regression constant (-0.015853041) for the effect of the peat fraction and time in days.
  • Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle b_{peat}} is the second regression constant (0.02348519) for the effect of the peat fraction.
  • Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle a_{tl}} is the first regression constant (-0.006617643) for the top layer thickness and time in days.
  • Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle b_{tl}} is the second regression constant (0.010061616) for the top layer thickness.
  • Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle a_h} is a regression constant (-0.200468677) for the change in surface height, for example caused by added materials.
