How to import an ArcGIS SLPK file
How to import an ArcGIS SLPK file:
  1. Open the Geo data wizard
  2. Choose as type either Buildings or Measures
  3. Choose as import method the I3S SLPK file option
  4. In the next step, either choose the height defined in the model (datum height) or place the models on top of the terrain.
  5. After selecting the file, continue to step 4
  6. In step 4, either create a new building with the uploaded model (in the next steps you can choose a function for the building), or choose to replace an existing building and function with the new model. If you have chosen this last option, you can finish the wizard.
  7. If you have chosen to create a new building, choose a name, function and stakeholders and then finish the wizard.
  8. Depending on the type you have chosen at the start of the Geo data wizard, the building is directly placed in the Tygron Platform project or a new Measure is created.
  • When the SLPK model contains no textures, the 3D model will be plain white
  • Currently, Wrap mode: repeat is not supported in atlas textures
  • Only textures in JPEG format are supported
