How to configure the Travel Distance Overlay for Pedestrians
Revision as of 10:05, 15 January 2021 by Godelief@tygron.com (talk | contribs) (Created page with "===Setting up the overlay=== {| class="wikitable" |style="width: 5%"|1 |style="width: 50%"|Add a Travel Distance Overlay. Adjust the grid as desired, 1 meter will give a nice...")
1 Add a Travel Distance Overlay. Adjust the grid as desired, 1 meter will give a nice resolution in our example.
File:Add Travel Distance Overlay1.jpg
2 On the Keys tab of the overlay, on the right side of the editor, the defaults keys ROUTING_AREA and BLOCKED are already filled in. In more advanced setups, added custom keys ('FOO') can also be selected in the drop down menu for each of these keys.
3 on the Attribute tab the following attributes can be adjusted to fine tune the desired outcome on the overlay:
  • TRAVEL_DISTANCE
  • FILL_DISTANCE
  • ROUTE_CARS
  • ROUTE_PEDESTRIANS
File:Attribute Tab1.jpg
