How to add an Area
Revision as of 09:47, 13 January 2021 by Bobby@tygron.nl (talk | contribs) (Created page with "===Adding and removing areas=== {{Editor location|Areas}} To add an area to the world select "Add" at the bottom of the Left Panel. A new area will be ad...")
Editor → Current Situation (Ribbon tab) → Areas (Ribbon bar)
To add an area to the world select "Add" at the bottom of the Left Panel. A new area will be added. To remove an area, select an area in the left panel, and select "Remove" at the bottom of the panel. Template:Editor steps
